#11 |
I wonder if anyone on the boards has pulled their manual slusher, and put in an auto, and has all the parts in a box next to my toolbox?
![]() ![]() Point out the parts number their GC, on Dave H 's snappic, and then we'll see what's here... |
#12 |
![]() Join Date: Oct 2004
The part needed isn't on the image of the console, there's no image available but if you turn your console plate over you'll see the shift boot attached with four screws. There's a metal fastener that snaps over the plastic stud that the screw threads into. GC needs the probably zinc colored nut that snaps over the plastic stud. I'm quite sure that's correct, it's been a good while. Take a snapshot of yours, yours should be close by!!
#13 |
Woulda' got it posted quicker, but 1-HOUR photo was jammed, and the train, and had to deliver a baby...
![]() So we huntin' the Ace nut? Or the Deuce nut? |
#14 |
I have GM Parts Catalogue for C4 in 12 .PDF files - about 2 Gigs total, if mods / admin wants to tell me how to upload it to the servers...
Oops - 21 .PDF's, only 380 Megs. Last edited by Schrade; 01-30-2013 at 08:31 PM. |
#15 |
The acorn nuts have nothing to do with the discussion. If you remove the screws you'll see the nut I described, snapped over a plastic stud. Simple enough I thought!
#16 | |
I'm kinda' slow sometimes there Sir ! ![]() But OTHER times now, I'm snoozin' ![]() And I need a pic of the ECM separated from the harness interface, if anyone has it. Looks like it has connectors IN SERIES ![]() |
#17 | |
So if you were to remove the shifter leather boot from the console shifter plate, these four little buggers are mated to 4 hollow posts on the underside of the console.
#18 | |
If he removed the screws and the shift boot the only thing left would be the retainer/nut that I mentioned. It would be exactly as you described in the quoted text. For cannibalization I mentioned earlier where and in what vehicles. There should be busted up console plates everywhere. Find an A4 plate and there would be 6. I'm guessing you bought a core that the boot and hardware had been removed from? If you could get the screws also it would be a plus, I believe it likely includes a plastic washer or originally did. |
#19 | |
#20 | |
Lol a bayonet is a solution. No not really I did this on my pops 96 CE before he sold it a couple of weeks ago and bought a 2011 CTSV They have to be pulled/broken off cleaned out (Plastic removed) from these fastners. I would be interested if the upper trim is already trashed scraped etc. I would not want to damage a perfect upper shift plate from a MY 90 At the time I was thinking man I sould just buy these from GM but as WV points out its not an option at this time.
