Old 01-26-2006   #11
Default Re: T-stat question
Here are the codes: HVAC Diagnostic codes 0- System Faults (one of these will be set if your air conditioning controls have an LED flashing) 00=No Faults
01= Temp Door Motor Circuit Fault
02= Temp Door Motor Circuit Fault
03 = Ambient Sensor Open
04 = Ambient Sensor Short
05 = In-Vehicle Temp Sensor Open
06 = In-Vehicle Temp Sensor Short
07 = Solar Load Sensor Open
08 = Solar Load Sensor Short
09 = Low Freon Detected
10 = UART Failure
1- Temp Setting 60F to 90F
2- In-Car Temp Sensor 10 = HOT -130 = 230 = COLD
3- Outside Temp Sensor 10 = HOT -130 = 230 = COLD
4- Sun Load Sensor Max light Max Dark L98 38 183 LT5 115 -110 = 210
5- Ignition System Voltage 0 = 9 Volts -155 = 255 = 16 V
6- Engine Speed (RPM divided by 25)
7- Vehicle Speed
9- A/C System Mode 00 = OFF 01 = Re-Circulation 02 = A/C 03 = Bi-Level 04 = Heater 06 = Defrost 07 = Vent 10 = Manual Re-Circulation 10- Blower PWM 0 = 0 Volts 128 = 14 Volts 11- Program Number
00 = COLD -155 = 255 = HOT
12- Mix Number -155 = 255 = COLD 00 = COLD
16- Coolant Temperature In degrees C
17- Solar Correction 114 = Max light 128 = max dark 30- Stored Full Hot Value 0 to 50 31- Temp Door Travel Range 100 to 200 34- Temp Door Position Requested 00=Full HOT -153=253=Full COLD 35- Compressor On Time 0.1 second increments 36- Number Of Times Below Critical Time 37- Software Version Number
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 01-26-2006   #12
haber rj
Thank you for the code read out iformation I will print this out and keep it with the rest of my files.
Cheers haber rj
haber rj is offline   Reply With Quote
Old 01-26-2006   #13
Thanks to Hotrod, Bill and Steve for the info! Haber rj's right about our forum... if it wasn't for us helping each other I know for sure I'd have an uphill battle.
Steve those codes are in the Helm manual, right? I think I remember seeing those in the A/C section.
Thanks again guys for the help!
Old 01-26-2006   #14
Yes..
Steve
1990 Red/Red #1473
Old 01-26-2006   #15
Demps
Demps's Avatar
Stant makes a good 180 deg replacement thermostat #14068.
Do no cut the bypass spring to try and increase the flow. You can drill 2 1/8" holes in the flang that the radiator can handle. Lower it to about a 168 deg. Changed a radiator in a friend's car as a result of the cut spring slipping off of the bypass block.
Ted
Old 01-27-2006   #16
Thank you Ted for the info!! You guys are great. I would never do any cutting on the by-pass spring...too far over my understanding to be messing with that stuff. I just want to help the car run a little cooler when I get into B to B traffic. Thank you for the Stant P/N! I'm going to try that one & see what happens to the temps.
Thank you all for the input!
Old 01-27-2006   #17
haber rj
Tom trying not to sound to laim but where would I find one of these 180 Stants, I am heading to the states soon and I would try and find one when I am there, I don't think that I could find one up here in Canada.
haber rj
Old 01-27-2006   #18
top o the morning to ya haber rj!!
I would think that any auto parts store would carry Stant cooling system products. I know the NAPA stores & the CarQuest stores by me have Stant's line of products. I'm not sure about AutoZone but I'm gonna try them @ their web site.
Hope that helps! Oh, ya know there are no Q's that are lame...besides go look up some of my Q's from when I first got my Z...talk about sounding lame!
Old 01-27-2006   #19
haber rj
Hey mate for a guy who has spent a much time around cars as I have drag racing super stockers, stockers, super gas, super comp etc. ect. I feel like I have never picked up a wrench in my life when it come to this car, it just scares the h--l out of me. I know most of it it just not understanding how these new machines work, but I absolutely love everything about this car, my wife tell me that I am like a little kid, everything excites me about it and everyday I learn something new, and I have you and all the other members to thank for it and it is really appreciated, I will be calling again.
Cheers haber rj
Old 01-27-2006   #20
Then you got a PhD in carology!
The only thing I got in my resume is the mechanical restoration of a 72 LT-1 A/C coupe that I did when I was a kid, 25 + yrs ago. Stupid kid I was, I bought a used race car! Never buy a used race car again...but I was young & stupid...I put the car back together & it even ran fine! It was my first corvette, and 20+ yrs later the ZR-1 is my second corvette. I guess I can say that I've had quality, not quantity...for sure! Damn I've been fortunate!
These cars can cure a bad day!
