Old 05-11-2015   #131
Default Re: Frankenplenum
Why not test it first, then worry about color..
Old 05-11-2015   #132
Obviously test fit is in the plan.....going on one way or another
Old 05-11-2015   #133
Well, that is not what I meant..
not Test Fit.. Test it, meaning.. why make it pretty if you put on and it makes the motor run worse..
I suggest test it out for a while first before making it pretty
Old 05-15-2015   #134
She is about 1/4 too tall.......will shim the hood
Old 05-16-2015   #135
just DON'T CUT IT!!!
I am telling you I will swap you if you are going to cut the hood
Old 05-21-2015   #136
Runner no longer shrouded....roof of runner raised to reduce curve and 36mm all the way through
Lipstick on the pig
Old 05-21-2015   #137
Inside Stock plenum
Old 05-22-2015   #138
those runners look as if they were sanded smooth prior to the black PC or is the PC really thick to make it smooth?
Old 05-22-2015   #139
No black gloss really covers well...no sanding
Old 05-23-2015   #140
Definitely going to need to shim the hood....and even take 1/4 inch out of the center of the plenum cover(its 1/2 thick)
