#131 |
![]() Join Date: Jul 2007
Why not test it first, then worry about color..
#132 |
![]() Join Date: Mar 2007
Obviously test fit is in the plan.....going on one way or another
#133 |
Well, that is not what I meant..
not Test Fit.. Test it, meaning.. why make it pretty if you put on and it makes the motor run worse.. I suggest test it out for a while first before making it pretty
#134 |
#135 |
just DON'T CUT IT!!!
I am telling you I will swap you if you are going to cut the hood
#136 |
Runner no longer shrouded....roof of runner raised to reduce curve and 36mm all the way through
![]() Lipstick on the pig ![]()
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 05-21-2015 at 10:07 PM. |
#137 |
#138 |
those runners look as if they were sanded smooth prior to the black PC or is the PC really thick to make it smooth?
#139 |
No black gloss really covers well...no sanding
#140 |
Definitely going to need to shim the hood....and even take 1/4 inch out of the center of the plenum cover(its 1/2 thick)
