#91 | |
![]() Join Date: Nov 2007
![]() As for the "unsuspecting", you can add all C5s and base C6s to the "road kill". ![]() ![]() P. |
#92 | |
With my 19" Z06 wheels the 4.30's would reduce down to 4.10's or so. I'd at least like to raise the current gearing which is 3.45 but runs as if it's about a 3.0 gear. A 3.90 gear should get me very close to the stock setup. |
#93 |
![]() Join Date: Dec 2004
From the peanut gallery.......A tip 'o the hat ( a ZR-1 hat ofcourse! ) to you Dom.
![]() That looks like it will be another FBI-land Killer Z! ![]() Tom
#94 | |
Actually tip of the hat goes to FBI guyz! Pete, Kevin, Al, Bob G., Marc are all very helpful and real enthusiasts when it comes to the ZR and LT-5. They're the pioneers who have spent the time to investigate, the trial and error and money it costs relentlessly pursuing the power and performance. Paul and =Jeff= just are always ready to lend a hand or tool. ![]() ![]() |
#95 |
![]() Join Date: Mar 2004
#96 |
Here's a Before and After when looking at Ported Heads + Intake Cams v.
stock heads and ported top end. At the end of the day, its significant. ![]() Last edited by XfireZ51; 03-08-2024 at 02:10 PM. |
#97 |
At our last pizza night, I asked Marc if he could access the final run from his tuning session for Paul W's motor. He was kind enough to send it to me last week and so I have attached a .jpg with each of our final runs superimposed. Paul's run is in BLUE, mine in RED.
As you look at this, recall the variables still in place when doing a apples to apples, but regardless its an interesting comarison. The differences are: 1. Different dynos although both are DynoJet 2. Paul has used the Pete the Greek porting template 3. Paul has stock cams 4. My heads were done by VanDeventer 5. My cams are Pete's Stage 1 intakes at 236/.425" single pattern profile 6. Paul has SW 2" primary headers/ I am using 1 7/8" Watsons. We're both using SW Xpipe and MFlow mufflers. Also if you look at top of Dyno run, you'll see that Gear Ratios are different. Not sure what that means or why because Paul and I both have 3.45's. AFR is only available for my run since Marc uses his own WB during his tuning. The question that occurs to me is whether porting or cams is the bigger bang for the buck. It would be interesting to get Dave Johnson's car on the dyno since he has the same cams I do, BUT with the cylinder head porting by Pete. Last edited by XfireZ51; 03-08-2024 at 02:10 PM. |
#98 |
![]() Join Date: Feb 2011
Too close to tell if they weren't dyno'ed the same day. A drag race might be the best way to find out who has the most area under the curve.
#99 |
