Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 10-11-2010   #11
jrd1990zr1
jrd1990zr1's Avatar
Default Re: High level brake light
Originally Posted by gbrtng View Post
What does the NCRS manual say?
I was told by the judge it should be 4Y on the right side. 1Y was only used in the base cars.
This seems strange to me since I have a second 1990 which was top flighted at a NCRS National event with the same markings. This car was judged using the first edition of the manual. The second (current) edition is not worded clearly and could lead the judge to believe the ZR1s should be 4Y.
If I remember correctly the ZR1s came down the same line at BG so it would not make sense they would use a different lense.
I would like to get this corrected for any other ZR1s judged in the future. It appears they used this same lense from at least 1990 all the way to 1995.
Thanks, John
Old 10-12-2010   #12
JThomas
JThomas's Avatar
FWIW my '92 ZR-1 has DOT 86 and 1Y. It is VIN #0068 and currently has 106,500 miles.
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 10-13-2010   #13
The light was the same on all cars,why would the base car be any different?
Old 10-13-2010   #14
maybe tom barr can shed some light on this subject for us
Old 10-13-2010   #15
barrhere
barrhere's Avatar
The Manual has been corrected for the next edition. It should by Guide 1Y not 4Y.
barrhere is offline   Reply With Quote
Old 10-13-2010   #16
glad to hear from you tom.
Old 10-14-2010   #17
jrd1990zr1
jrd1990zr1's Avatar
Tom,
The question came up using the 1990 second edition manual which came out just recently. Are you saying it will be corrected in a future manual, say 3rd edition? Any idea when the new manual might come out?
Just so you know, my car was judged last saturday by a NCRS regional director who interpreted the 2nd edition as saying the 1Y was not correct. Maybe you could post on the NCRS board this error to let all folks judging C-4s know should it be a while before the 3rd edition is published?
Thank you,
John Dergosits
Old 10-16-2010   #18
ZRapid-1
Since the manual is going to be updated, then I believe the correct term for this light is Center High-Mounted Stop Lamp (CHMSL). That's right out of my 1990 Owners Manual.
Might as well be consistent between documents.
ZRapid-1 is offline   Reply With Quote
