Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 09-18-2010   #1
Default Rear wheel bearings/U-joints
After meeting Phil at the Great Falls coffee and car I went over to his house and we started with pulling half shafts followed by wheel bearings. It took a large hammer, huge C clamp and a vice to persuade U-joints out.
Needless to say, after 10 years and 70,000 miles, both wheel bearings were pretty tired. Also noticed quite a bit of scoring on one U joint.
Phil, being a neat guy insisted on cleaning and even taking wire brush to heavily rusted pieces - yokes.
With half shafts out of the way bearing hubs were pretty easy to remove.
After buttoning everything back up he somehow sweet talked upper K member to side frame bolt which I was convinced to be stripped (hole in the frame not the bolt). This took care of an arthritic clunk I was getting coming to a stop.
Combination of new wheel bearings and U-joints eliminated trashy, clanking noises I was getting going over patchy roadwork - kind that makes the tail twitch from side to side.
Finally the rear suspension sounds the way it use to when young!
Sounds simple but the actual work took solid 9 hours but worth it and more.
I am slowly running out of stuff to do... Can't believe it!
Old 09-18-2010   #2
Scrrem
Scrrem's Avatar
Default Re: Rear wheel bearings/U-joints
Good job Yun, you have been chasing that noise for a while now.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 09-18-2010   #3
Phil did the work - I helped. At least I know the sequence and procedure.
Old 09-18-2010   #4
Wazooooo! Awesome!
Glad things worked out and your happy Yun!
Old 09-18-2010   #5
Thanks David. You da one who got me started. Now I can't stop!
Old 09-18-2010   #6
VetteMed
I'm doing the same stuff on my 189,000 miler -- all original parts - talk about crusty! One of the u-joint endcaps was grenaded, no needle bearings left, all seized metal on metal. Guess that's where that clunking was coming from!
Old 09-19-2010   #7
QB93Z
QB93Z's Avatar
Good job Phil and Yun!
Old 09-19-2010   #8
Thanks, Jim. Another skill set.
