08-31-2010 | #11 |
Re: Plenum pulled now for the questions?
Z51JEFF - I know very little about fuel injector construction and my confusion on the subject is not helped by companies that sell rebulid kits or offer to rebuild the ones you own. Granted they do not specify which ones they can do but it must be possible for some. That is why I asked for guidance here. That said I am going to purchasing new injectors.
1991 ZR1, White/Red. |
08-31-2010 | #12 |
FYI on a recent post regarding OEM injectors I was told that if an injector measures good when cold they may be bad when they are in a hot engine.
Make sure to touch base with Jon at FIC. Good luck, John |
