![]() Join Date: Jan 2006
I have a few questions and observations. My experience is mainly with '95s but I've worked on or helped others work on other years.
Some observations: 1) I think the plant used what ever parts they had at the time to put on cars. 2) I have '95s with different spring rates--I'm assuming at least as they have different markings. 3) I have seen different spring rates on other years. 4) The '95s became more of a GT car than the '90 Sports car. Questions: 1) What do the spring rate codes mean. 2) What are all of the spring rates, codes and correlation between the two? I have seen "FHA 1-3" and an "FHA 1-5" fronts. What are the rates? I have also seen "RHY 1-1" and "RHY 1-3" rears. What are the rates? Is there any difference? Ted |
![]() Join Date: Aug 2008
![]() Took this from another website, maybe it will be helpful.
Ken 63 vert 91 ZR-1 #786 91 Z-07 (sold) 67 coupe (sold) 72 LS5 coupe (sold) |
![]() Join Date: Feb 2006
I manage a division of a Spring manufacturing company here in houston.
We have calibrated Spring Testers we use everyday and can inspect and document the rates for as many springs as you wanted to test and tag & identify each with the rate results. NO CHARGE !!!!! Let me know if that's something you may want to do sometime. If so ship them to me and I can do it the same day I recv them and ship em right back to you that same day. could also re-shotpeen them too. and mag particle test em too. ![]() Luis |
Thanks Ken and Luis. Luis great offer!
I found the link I was looking for...My post is geared toward tying it all together. http://zr1netregistry.com/ZR1_suspension.htm Are the sub-category [# dash #] (e.g. 1-1) relevant? Are the three letter designation (FHA) relevant? Do ZR-1s have different springs amongst like years; different years? Ted |
