Old 07-11-2010   #1
Default Coolant tube bolts
Well I snapped off 7 of the 8....I thought the tube would slide off once the head either broke off or was drilled off....but its locked on good.
I shot some PB blaster in the bolt holes to see if that loosens them up.
Any ideas?
Lee
Old 07-11-2010   #2
BOB HDZ
BOB HDZ's Avatar
Default Re: Coolant tube bolts
heat!
BOB HDZ is offline   Reply With Quote
Old 07-11-2010   #3
OEM gaskets leak coolant into the bolt & it gets rusty. In this instance, a plain gasket is better than the silicon bead on the OEM. Are you going back with stainless?
Old 07-11-2010   #4
I like the OEM look, I will probably go with stock or allen head covered in anti-seize. Of course I forgot to order those gaskets.....although I might have a spare set.
Had to drill out one of the airhorn bolts also.
Old 07-11-2010   #5
Do you have one of those hand held hammer type impact drivers. I don't recall what they are called, but motorcycle shops use them. If you can get use one of those, they're a big help getting out torx head bolts.
Old 07-11-2010   #6
Toyvet1
Lee I have a set if Jerrys gaskets if u need a set quick....
Old 07-11-2010   #7
Thanks, I need to get a clutch too, might grab one from Paul....I will have to look I might have a set from the 92 I did not remove the bolts....but might have given that set away to someone.
I am also seeing the secondaries hanging up on one side might explain my 310rwhp a year or so ago....
Old 07-11-2010   #8
Wonder if that isn't Han's problem?
I used stainless Allen head bolts with anti-seize.
Old 07-13-2010   #9
Wow these things are no budging....are these threaded the whole way through or just in the IH housing....I cannot image its threaed in the tube
Old 07-13-2010   #10
No threads in the coolant outlet tube, only in the inj hsng. The bolts, for some unknown reason, are threaded all the way to the bolt head. Lots of friction surface for rust. Heat & soft mallet.
