Old 05-08-2010   #2
Default Re: Service engine soon
I never had a 21 but the FSM has a diagnostic path to use to check it. I guess it could cause a higher than normal idle if the ECM thinks that the blades are open and they actually are not.
The simplest way to do one check is with a VOM. KOEO, throttle closed, probe TPS with VOM at dark blue ( ckt 417 ) to read V output.
closed throttle V range = .46 to .62 volts. If it's out side the range you could try to adjust it back into range using the mounting screws. They go into slots which allows for some adjustment. I would guess if it's high & you can't get it back down then the next check I would do is on the Black wire ( ckt 452 ) that is the sensor ground. If it's open it will set a 21. Or maybe check the 452 wire first for a bad ground, then check the output V?
I hope this helps some?
