Old 04-17-2010   #1
Default Re: SYS light,,
according to my 90's FSM a 41 = wrong or bad MEMCAL.
Old 04-17-2010   #2
I think MEMCAL is FSM-speak for "chip" or EPROM or PROM ( not the senior prom either )
Old 04-17-2010   #3
Toyvet1
It was a C41 code read from grounding the G & A terminals and displayed on the speedo not the SES light is that still the correct reading? I have a FSM but am having a hard time finding the codes in it ...
Old 04-17-2010   #4
That C41 is for the CCM not ECM.. it is a ECM/CCM COMMs error. either the UART in the CCM is bad, the CCM is bad or one of the other components is bad that connects tot he same Serial bus
EBCM (ABS ECM) AC controller and Radio also connect tot he Serial line
Old 04-17-2010   #5
Sorry, my bad
I've never been in the 8D section of my FSM. You should see how clean the pages are. Your page is 8D-47, near the back of the thick book that has "Service Manual" on the cover. It's not the supplement LT5 book or the Electrical Book.
I do not have a scanner on my P/C so I can't send you the pages.
The opening step of the diagnostic chart is not very involved. I can write it in a post if need be?
Old 04-17-2010   #6
Toyvet1
Okay this morning I removed the stereo head unit that was repaired this winter and the sys light is gone. -=jeff=- is going to borrow me a spare and see if that is the problem.
Also am going to try a different ECM to see if that helps the SES light issue.
