Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Technical Questions
Old 04-05-2010   #1
Geof180
Unhappy 1996 LT1 O2 Sensor
hey everyone -
i have a quick question here (see title)
it seems as though each year - in the march / april time frame - over the past few years, my check engine light comes on..
using the scanner, it is always code P0151 - which is a faulty right front 02 sensor..
i'll replace the sensor, and then in a year, it will go bad again.. wash, rinse, and repeat...
what would cause this part to fail so early?
they are recommended to be replaced, what? every 30K miles or so? i am not driving that far each year...
[FONT=Arial][SIZE=3]Geof[/SIZE][/FONT]
[FONT=Arial][SIZE=3]1994 torch red on light beige ZR-1 #107 [/SIZE][SIZE=1](thanks Nick)[/SIZE][/FONT]
Geof180 is offline   Reply With Quote
Old 04-07-2010   #2
VetteMed
Default Re: 1996 LT1 O2 Sensor
Are you losing coolant? The silicates in the coolant, if escaping into the exhaust, could be contaminating the sensor.
Originally Posted by Geof180 View Post
hey everyone -
Old 04-12-2010   #3
A bad or failing cat can cause the 02 sensor to fail
