![]() Join Date: Nov 2008
I'm curious too. Given a set of heads ported to "today's" standards, what cams would work best with ported heads on a 350, 368...so on. Drivability/intended use aside.
Sounds like the "while I'm there" bug has hit. Xfire just spent lots of $$ on ported heads and doesn't want to put stock cams back in! I'm in the same spot. ![]() |
#2 | |
The LT5, not so much. If Marc H. is lurking maybe he could chime in. |
#3 | |
![]() Join Date: Aug 2006
![]() Join Date: Mar 2007
I have pointed this out in the past Sean Hyland builds 600hp Ford DOHC Cobra motors.....also has developed cams.
#5 | |
![]() Join Date: Nov 2007
Could you post the ISBN# for that S. Hyland book? (ISBN# usually on the back - often next to the a bar-code.) It would make for an interesting read. ![]() P. |
