I've always had this issue where the plenum coolant line, PCV line, and the I/H coolant extension interfere. I never thought much of it until I put two and two together about the slowly disappearing coolant, and the fairly clean nature of the two intake runners next to the coolant passage.
Here is a picture: ![]() I believe this keeps the plenum from really seating properly here. If you feel it, you can not move the PCV line, it is definitely pinched. The last time I removed the plenum, I hammered the PCV line slightly oval to try to fix it, but that didn't really help. Has anyone seen this before? Any thoughts? I think the coolant nipple on the plenum should be rotated to point more vertical, but I'm not sure how they are retained. Can I just twist it up? Or will that ruin it or cause it to leak? I also thought I could grind that bit of the coolant extension down, but it seems like there should be a less destructive way to fix it. |
![]() Join Date: May 2007
Bob, I just checked two cars, the 1990 and the 1994. In both cases there is 1/16 inch clearance between the coolant tube and the PCV tube.
Interestingly, when I lifted up on the PCV tubing to try to make contact with the coolant tube, I could not get them to touch. The PCV tubing contacted the under side of the injector housing bolt flange preventing contact with the coolant tube. I wonder if your plenum's mating surface has been machined in the past to make a better seal to the IH's? I don't know how the coolant tubes are sealed into the plenum, but I have always wondered. Some guys put a non-metalic spacer between the plenum and the IH's to reduce heat transfer. Maybe that would help your problem. Jim |
#3 | |
All good questions. Does the Size "thickness" of the Coolant outlet pipe gasket come into play here as well?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 03-18-2010 at 10:09 AM. |
#4 | |
![]() Join Date: Aug 2006
However, you have to make sure you have clearance between the underside of the hood and top of the plenum before taking that route. I will check mine later. ![]() |
![]() Join Date: Jan 2004
Thicker plenum gaskets are available, ask Jeff about them - he had some a while back.
![]() Join Date: Dec 2004
This makes me want to go look at mine.....which I'll do this evening. I'll take some picts also.
However now that you bring this up I want to say that I think mine is configured the same as yours is configured, with that interference between the PCV hard line and the 90* elbow from the plenum, I think. To your Q about the attachment method. On my spare 91 plenum those pipes are a press fit with some kind of hardening dope. Or at least the fittings on the 91 plenum I bought were that way. Now I do not know if the machinist who did the porting work removed and reinstalled the fittings? It's my opinion that if you try to move those you will break the seal on the "mystery" sealant used. I say this because when I pulled that elbow out the sealant was quite hard in it's dried ( set up or cured ) state. I can tell you for sure that is not any kind of standard pipe dope like teflon pipe paste or even RecTo-Seal ( the stuff used on oil & gas lines with threaded ends ). I also doubt that it's an epoxy, or how would I be able to break that elbow loose without distorting it? It reminds me of the old #7 aircraft sealant in that it dries to a hard state, except for the color. The stuff on my elbow was white to light tan in color. Sorry I can't add anything really useful. ![]() ![]() Tom
![]() Join Date: Jul 2005
Just checked my 90. The PCV line is dimpled where the two cross. Looks factory. I use the thicker gaskets from Jerry and they do not touch. However, it looks like they would if not for the dimple!
Not true, now I know not to try to twist it to a different position.
I'm not a fan of using a spacer, I'd be afraid of hood interference. A thicker gasket would be ok, but I'm not sure that would buy enough space? Also it means yet another plenum pull... I'm getting a bit tired of pulling it all the time. I might go the route of pulling the coolant elbow off and grinding that area down a little. Though that will be a pain too because the last time I tightened the bolts on them, I got the feeling it was the last time they had in them. |
Bob,
I have you covered if you end up needing a few coolant elbow bolts. |
#10 |
okay I went to look at my car & took some pictures, 4 to be exact and I'll post what I think is the best one. The rest you can use the link to look at if you like.
![]() This the link to my photobucket page: http://s215.photobucket.com/albums/c...omZR1/my%2090/ ![]() Tom
