#221 |
![]() Join Date: Jan 2009
John, What was the criteria for assigning an EX#? For example, your snake skinner had a standard VIN: #081 but Snake skinner II had EX6153? Thanks Eric
#222 |
The picture is of the back of the car and theres no interior shot.
#223 |
#224 | |
Some VIN vehicles were turned into EX vehicles when enough experimental parts were installed to where the vehicle would become experimental. Discpline on this was not that great though |
#225 | |
#226 |
#227 | |
![]() Join Date: May 2005
http://deliquescence.net/~tyler/prototype/87_build.jpg This is a copy of what was in the frame of mime which means it was on the frame build part of car as it went down the line. When the body was dropped on the frame a worker put the 'extra' sheet in the frame. Eric you can get a copy of the build sheet from the NCM. On this document you can see all the numbers tied togeather on one page. The ex # and p# in the KOH line and the actual assembly line build on the top right. I have never seen the rpo codes lined out like this except on the 88 prototypes like mine, I can only assume the build computer did not have them programmed as options yet. Tyler |
#228 | |
http://deliquescence.net/~tyler/prot...production.jpg That will tell you what the car started out as off the production line. Tyler |
#229 | |
#230 |
I think P cars were not mutually exclusive. #074 was 9PR110. No "P" nor Y. This car is an "S" I am sure GM had a S group. So it's "P" number is S9YKH1 if that makes any sense. My space on the build sheet does not have the same info yours has. No EX# No P number. THis car belonged to the Chevy Photography/Campbell-Ewald. A whole different group. (which is probably why it is still here. John and his guys seemed to chew up those P numbers. Not to many of those left anymore but at least 5 PR cars are still here.)
