When I am driving straight ahead and let off the gas the car squirms to the left then back to the right when I get on it again. It sorta feels loose in that respect. Would beam plates fix it or do I have another issue I'm not aware of? Also, the car looks like it might be listing towards the passenger side a touch.
#2 | |
Beam plates will help to an extent but it sounds like something else is going on here as well. The beam plates have the added benefit during R&R of the transimission and I highly reccommend them for GP.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-20-2010 at 01:34 PM. |
#3 | |
![]() Join Date: Aug 2008
![]() Join Date: Feb 2004
One suggestion would be to check your half shaft universal joints, mostly likely the passenger side outer joint.
George |
If the shifter doesn't move when this is happening, then it isn't anything to do with transmission play and beam plates, although like my Cycloptic friend has pointed out, you just can't go wrong by putting them on.
Check all the easy stuff first, tire pressure, etc. Put a jack under the rear and give a rear wheel a hard tug (checking for suspension play). Take a good look at all the bushings under the rear. Follow behind your ZR1 while your best friend flogs the sh!t out of your car. You won't see anything, but he will surely enjoy it. ![]() Seems that there was a similar problem posted here back around October or so. Maybe do a search and see what pops up. TomC "Crabs |
I don't think the shifter is moving, but i will have to watch it next time I drive it.
Rick, maybe I'll bring it by the shop where you work and let you drive it, then I can have a second opinion. Next time you drive yours, let on and off the gas a few times paying attention to what happens in regards to the direction the car maintains and then drive mine. I'm also gonna need your help to get me going on these injectors to bro. ![]() |
#7 | |
