#21 |
![]() Join Date: Feb 2006
durned hamsters out for lunch again ...
#22 |
Mine's running pretty good.
#23 |
#24 |
![]() Join Date: Jun 2004
Need to get a new hamster as this one is dead!!! This is just agonizingly slow. Please help!!!!!!!!!!!!
95 ZR-1 BLK/Gry #392 LT5 Reg# 868 *RIP* ZR1NET Founding Mem #155 Last edited by carter200; 01-15-2010 at 10:22 PM. |
#25 |
#26 |
I will not drive mine for a bit either
![]() ![]() ![]() Last edited by Dynomite; 03-08-2010 at 12:20 PM. |
#27 |
I can see why...you are low on brake fluid. You better get a jug of that out and fill'er up before it goes dry.
#28 | |
![]() That is because I have my calipers on the bench ![]() I will get a JUG or two JUGS when I get the calipers back on ![]() |
#29 | |
![]() Join Date: May 2008
I'm having major problems too and often its server unfound white page or the lag is just awful. All from high speed connection and on 3 different pcs. |
#30 | |
I open a thread and then go and remove some component on the Z ![]() Or as Jeffvette does...open several threads in separate windows ![]() |
