#21 |
![]() Join Date: Aug 2008
You can also just stick the stem in your mouth and "SUCK ON IT BABY" and achieve the same thing.
#22 | |
#23 |
#24 |
rick , i think your light flywheel is the reason your car feels different . i have one in my 90 and when you stab her from a roll,poof she is gone .the 92 has the stk unit still in her and feels much slow, but actually she isnt . just my 2 cents
#25 |
I didn't think it felt slow. 395rwhp plus 3.92 gears headers/corsa. That thing was a neck snapper. It was a thrill to drive. Mine doesn't hold a candle to that one. And your black 90 is putting out somewhere in the 429rwhp range I think and with 4:10 gears. Pete's car is the fastest 350cu Z I've seen so far but yours are the 2nd fastest I've seen and driven. I've watched both you guys videos. There all over the net. I love watching them.
#26 | |
Pete |
#27 | |
#28 | |
![]() Join Date: Nov 2007
![]() *edit* in my original post I said "vacuum gauge" I meant vacuum pump. My Mighty-Vac has a gauge on it and I was thinking of that.** Last edited by 32valvZ; 01-06-2010 at 06:21 PM. |
#29 |
![]() Join Date: Dec 2003
Mine were installed backwards? (some controversy about that even). With the plenum off, I checked operation with a hand vacuum pump before turning the actuators over, and afterwards. There was a significant difference in operation after I put the actuators on "correctly". It took more vacuum & hung a little before opening completely, with the actuators installed "correctly". It was a no brainer, I returned them to the backwards? position.
I've not heard of any operational problems with actuators installed backwards?, other than it "just looks crooked."
#30 |
Now what
![]() I am going to hot wire my spare vacuum pump and then hook up the secondary vacuum lines (I have an extra roll of vacuum line) and see what they do ![]() Besides that...I just ran my cell phone through the wash machine for five minutes...... ![]() If anyone is reading this....how does that black plastic under the radiator fit in place....I forgot that also.....da....this is one of those days ![]() Last edited by Dynomite; 01-06-2010 at 10:14 PM. |
