View Poll Results: Which antifreeze/coolant do you use?
Autozone 5 10.00%
Castrol 0 0%
Champion 0 0%
Durex 1 2.00%
Fleetguard 0 0%
GM Dexcool 2 4.00%
GM Ethylene Glycol 6 12.00%
Havoline 0 0%
Mobil 0 0%
Napa 13 26.00%
OES 0 0%
O'Reilly 3 6.00%
Peak 0 0%
Polar 0 0%
Prestone 9 18.00%
Prime 0 0%
Proline 0 0%
Shell Rotella 0 0%
Sierra 1 2.00%
Texaco 0 0%
Water Wetter & Distilled water only 3 6.00%
Zerex 6 12.00%
No additives just plain water 1 2.00%
Turbo Power 0 0%
Voters: 50. You may not vote on this poll
Old 12-29-2009   #1
Default Re: Which antifreeze/coolant do you use?
I am not using this yet but am thinking of using this
Actually I have not found ZEREX original formula yet
This Poll will be as exciting as the oil Poll I am sure.
Old 12-29-2009   #2
Z Factor
Z Factor's Avatar
^^^ According to this chart it looks like it is one of two in the Zerex line that meet GM 1825 spec.
http://www.englefieldoil.com/PDF/Zerex_chart.pdf
Old 12-30-2009   #3
I'll go take a pict later, but I get mine from the chevy dealer. It's p/n 12378560.
It's expensive for sure, but it's what came in the car from BG back in 90.
I may go to the local NAPA store and see what they have on the shelf or what they can order that is an E-glycol silicate coolant 1825M spec. I have only one gallon of my GM stuff left after this yr's flush & refill.
Old 12-30-2009   #4
Hammer suggested to me a few weeks ago NAPA house brand coolant with the 1825M rating. Trouble is, I could not find a NAPA dealer around here that has not closed up and am still looking
Old 01-10-2010   #5
xlr8nflorida
xlr8nflorida's Avatar
I got 4 jugs of this for my 2 C4's.
Question, who changes the thermostat too and what all is involved?
Don't want to screw up my thermostat housing etc.
Old 01-10-2010   #6
Hammer suggested this in the Leaky Radiator thread
http://www.zr1.net/forum/showthread.php?t=10241&page=2
Re: Leaky Radiator
Another item that can blow radiators is if the thermostat wasn't installed correctly in the housing. Easy to check, but have the catch pan ready if you pull the thermostat (don't ask me how I know that). Make sure it's seated correctly. Hold it in flush with the housing, use the bracket (Marc's trick) or a putty knife while you tighten the lower housing bolt.
Old 01-11-2010   #7
lbszr
lbszr's Avatar
The local Chevy dealer carries original Zerex, but it's about a dollar cheaper at Savage auto parts. It says on the bottle it has silocates.
Old 01-13-2010   #8
95ZR1#418
95ZR1#418's Avatar
About a month ago I read a number of antifreeze threads and freaked out! Last year I had installed all new hoses, clamps, new 180 (& drilled out, as explained on ZR-1 FAQ) stat, & flushed the system. I then used distilled water, water wetter and 10% Prestone. So big mistake using Prestone (as I had read), it has taken a month but I will be receiving my GM antifreeze tomorrow via GM Direct. Then I will re-flush the system and make it 10% with the GM green stuff...I don't drive it in freezing weather & it stays in a heated garage.
So I think I have it right, finally...
95ZR1#418 is offline   Reply With Quote
Old 01-13-2010   #9
Per recommendation of someone here I went with Napa that meets the specs.
Old 01-13-2010   #10
Bell Curve
Bell Curve's Avatar
Prestone doesnt make any type of the good stuff
Bell Curve is offline   Reply With Quote
