Old 11-30-2009   #1
ZR1ROB
Default connector part numbers needed
If someone has the under plenum connector part numbers for the ignition module (3 way next to the long horizontal one at the back of the module) and the large 3 way that goes in vertically into the front of the module, and the secondary vac solenoid (white 2 way), i'd really be grateful. The tabs broke on me.
ZR1ROB is offline   Reply With Quote
Old 12-01-2009   #2
Default Re: connector part numbers needed
I don't know the part numbers, sorry. Maybe this site could be of some help;
http://www.rs-autosport.net/catalog/...roducts_id=192
Or perhaps this one;
http://www.rowand.net/Shop/Tech/Auto...Connectors.htm
Old 12-01-2009   #3
limey
These are the 4 items under the plenum.
90,91,92,93,94,95 Connector, Ignition Control Module 2 Way
USD $27.24
1210185
90,91,92,93,94,95 Connector, Ignition Control Module 3 Way
USD $43.76
12117339
USD $46.06
12167116
90,91,92,93,94,95 Connector, Ignition Control Module 4 Way
USD $50.30
12102776
limey is offline   Reply With Quote
Old 12-01-2009   #4
I can't remember all of them but one that connects to front of the ignition module, I swear, is a three prong weather pack (male).
Old 12-02-2009   #5
Ignition module connector on mine looks completely different from pics from Kurt.
Can someone post the pic for me? Somehow I cannot connect to my photobucket.
Could it be that 93up have a different connectors? Mine is a 94.
Old 12-02-2009   #6
http://i658.photobucket.com/albums/u.../Connector.jpg
This is the connector I had to replace for the ignition module.
Perhaps it's early year vs. later year difference...
Old 12-02-2009   #7
Jeffvette
That connector has a couple of places. TPS sensor, MAP sensor, and O2 sensors.
Old 12-02-2009   #8
On my 94 this same connector, slightly modified (razor cut parallel to the prong to duplicate busted one), fit perfect on one of front ignition module.
$5 at auto part store. Chevy dealer price was around $15 and would require wire splice. Guess which route I took.
Yes, it's identical to TPS connector.
Old 12-02-2009   #9
O.K! Now it comes back to me! My original factory connector was a 3 tubular prong weather pack with sort of rectangular plastic box with 3 round holes to receive weather pack. Then the whole combination (resulting in final configuration similar to what limey is showing) sliding into ign module.
Looking at Jim's pic on another post helped me recall.
Old 12-02-2009   #10
Hammer
Hammer's Avatar
Talking Re: connector part numbers needed
That's a standard Weather Pack male connector. Available at most NAPA stores. I just replaced a female end to that one, cost was $2.64 and the pins were $.67 each. I used them to extend the O2 Sensor harness.
http://www.weatherpack.com/
