Old 01-28-2006   #35
TheLurker
TheLurker's Avatar
Default Re: Update on injectors
The hot tip about cleaned stock injectors is that they tend to stick a bit after cleaning and sitting a while. The best way do do it is to install them and run the car the same day. Before installing them, bang them on something. When I have injectors on the test bench and they stick I just take a small hammer, like a tack hammer, and tap on them. That usually does the trick. So, taking that information a step further, just tap them around right before installing them. Then, get gas on them as soon as possible. You should be fine after that.
TheLurker is offline   Reply With Quote
