Old 11-17-2009   #1
rhipsher
rhipsher's Avatar
Default Wills 415 spacers almost done.
I've got to make a few small mods to them but for the most part they're done.
Our hard working 20 somethings on their 15th smoke break of the day.
Old 11-17-2009   #2
Default Re: Wills 415 spacers almost done.
Smoke less....more working time.
Rick, those are nice!
A dumb Q....the need for those would be to clear a dropped plenum floor? Sorry, don't mean to be asking about other people's speed secrets....
Old 11-17-2009   #3
limey
Blimey,
I could have hooked you up here & saved you a whole bunch of headaches, built them with or without nozzles. Clearance with the hood & allowing fitment for the nozzles was the biggest challenge for us.
limey is offline   Reply With Quote
Old 11-17-2009   #4
rhipsher
rhipsher's Avatar
The reason Will needed them was because he had someone machine the faces of his plenum and IH housings and they took to much meterial off so his plenum was sitting on his A/C compressor. He tried to grind a little off to make it clear but that wasn't enough. They only take 3 1/2 minutes a piece to machine. But of course programming and set up time takes much longer.
Old 11-17-2009   #5
mgbrv8
Beautiful work guys. The bed way of you CNC looks like a Haas.
Dave
Old 11-17-2009   #6
rhipsher
rhipsher's Avatar
Dave
Its a big 50 taper machine. A Puma 5025. There were two other jobs set up on that mill table. I just found an empty spot toward the back of the table and set the spacers up right there. The only thing that sucked was I had to lean way over one of the other jobs to reach the spacers and my shirt was getting soaked with coolant.
Old 11-17-2009   #7
jonszr1
jonszr1's Avatar
rick awsome work and you built them to his specks . instead of just buying something off the shelf .that way he was sure everything would fit just right .
Old 11-17-2009   #8
Originally Posted by limey View Post
Blimey,
WOW! That looks wicked!!
Old 11-17-2009   #9
USAFPILOT
USAFPILOT's Avatar
that NOS setup is cool! Nice job on those spacers Rick.
Old 11-17-2009   #10
rhipsher
rhipsher's Avatar
And I didn't charge him a dime for them. Just a favor for a friend. I don't think anybody will be able to beat that price.
