#11 |
![]() Join Date: May 2007
I agree, a switch would work. However, I will live with it as it is. The only time it has mattered is if I park the Corvette below another car on the lift which I haven't done because I am using the lift for maintenance.
Jim |
#12 |
Jim sent you a PM. Daryll
#13 | |
Wish you were closer to us! I will put pics up of our install when it is finished -- Z2, Focal speakers, Focal amps, JL subs, back-up camera. A Custom box that will blend forward into the center console and will have cup holders that actually hold drinks. It will be clean, based on functionality and will add a modern touch to the car. All the plastic in the car will be wrapped in suede or maybe a carbon fiber. The antenna will be shaved and a powered am/fm antenna will be added under the dash. Also we will make sure the design is one to where you can get to the brake equipment if needed without too much headache. The top holder will still function as well. |
#14 | |
http://www.zr1netregistry.com/forum/...ead.php?t=6145
#15 | |
