#21 | |
I know with my aftermarket chip I lost the upshift light which made me sad I'd like to find a way to get it put back in.
#22 |
![]() Join Date: Dec 2004
Thanks guys, Kevin, Bob & CAV!
Humm, I never thought about a chip turning off the shift light Bob. The chip I bought is just the replacement update for the OEM 1990 chip. Yes the shift light does work. I guess your bulb could be out? Maybe you have an aftermarket chip? Also thank you for sharing what you did at Englishtown. I hear ya about the GSC's, mine were old & hard & I replaced them with D3's. I guess I worry too much about the IRS, too many parts & no place to work. The stuff sure looks nice though! I hate to say this but I'm still partial to the detroit locker in my Mach1, that would do the trick in the launch department! Once the clutch is engaged & the speedo says something I have no quams about lett'in her rip, it's fun! I guess I'll never be a drag racer! ![]() Thanks for sharing Guys! ![]() Tom
#23 |
At Carlisle last Summer on the road course I watched a C5 Z06 hit it every time he was on the course. My friends ZR-1 had lower times, won his class and never hit the rev limiter once.
#24 | |
#25 | |
#26 |
For anyone wondering what it sounds like, here's me hitting the rev limiter in 1st gear. Not intentionally...
Hitting limiter ~1.5MB Last edited by Aurora40; 05-19-2012 at 10:41 AM. Reason: fixed link |
#27 |
Okay I know now that I have never let the rpms get to the limiter...I must be early enough at shifting in 1st & 2nd to stay off of the limiter...I guess if you use the shift light there must be a few hundred rpm cushion or I would have hit it for sure...the motor sounds so sudective up top I get mesmerized by the sound & almost forget the shift light!
![]() Man that thing sounds sweet, Bob!!! ![]()
#28 |
Well then here's me not hitting the limiter.
![]() Not hitting limiter ~3MB Last edited by Aurora40; 05-19-2012 at 10:41 AM. Reason: fixed link |
#29 |
Okay I had to think about this. I bought the GM updated Prom, code ABYK, from P & G Chevy. I had the 1990 OEM PROM. I looked after reading the TSB over at the Reg site & my symptoms matched so I put it down on my list. I know the shift light worked before I swapped PROM's and I know that after I did my plenum stuff I put in the GM/ABYK coded PROM and the shift light still works.
btw, Bob it sure does sound nice...sweet music you're car's making! You must be ![]() ![]() Tom
#30 |
How much damage will hitting the rev limited do over a long period of time
