I have started to take apart my lt 5 and as I get the heads apart I am finding the the secondary valves in each cylinder valve springs are bent or shorter or otherwise damaged. I am looking for a set of new springs any leads??? Also nee one valve keeper lost one takeing heads apart don't know how but cannot find it. Thanks, Mike
Try Marc H
Here is what i would do, since you're not going to find new OEM valve springs in the box, (You may find a used set) buy a brand spanking new set of heads from us. They come with all new valves and springs, as well as the holy grail cam cover emblems, new wear guides and such. $1500.00 per side, after you get done with all the work required to replace the springs with any aftermarket, clean the heads, you'll still end up with used heads and questionable provenance springs.
![]() Join Date: Dec 2003
I have a keeper you can have.....
I also have gaskets & seals. link is below my signature
![]() Join Date: Apr 2009
Take a look at LT5parts.com. I don't know anything about them but they have some valve springs on the site. $20.00 each
