Old 08-19-2009   #1
vettn71
Default Clutch Pedal to the Floor
Yep, looks like a bad slave and/or master on the clutch. I've read all the threads and my question is, which slave has the best chance or working and which should I definetly avoid? I really don't want t do this four times like I did with my plenum
JIm
vettn71 is offline   Reply With Quote
Old 08-19-2009   #2
jonszr1
jonszr1's Avatar
Default Re: Clutch Pedal to the Floor
contact bill boudreau. zfdoc. he will set you up .
Old 08-19-2009   #3
rhipsher
rhipsher's Avatar
JIm
Don't be so sure it's the slave. Twice my peddle went to the floor and twice I thought it was a bad slave cylinder when in fact it was a broken throw out bearing. If your lucky its a bad slave. But if its not! Well then you know the rest.:-(**|=
Old 08-19-2009   #4
Jeffvette
Start off by checking the fluid level in the reservoir. Fill it up, pump the pedal and see what the pedal does. It will only be a temporary fix. Like moving in and out of the garage.
Old 08-19-2009   #5
Kb7tif
JIm
I would always change Clutch master/Slave as a pair.
thepartsladi on ebay can set you up with both Gm original parts.
These should bleed out simple as a new pair. I know the slaves are 85.00 not sure on the master
Old 08-20-2009   #6
vettn71
Thanks for the input. I'll contact zfdoc (Bill) and see what he recommends. I did check the fluid. It might have been a smidge low, but was black. When I bought the car I had Corvettes of Dallas go over it ans change out all the fluids. They didn't do the clutch, as they said it would cause more problems than it would fix. One year later, here I am.
Old 08-20-2009   #7
Sgreg
Sgreg's Avatar
JIm
Jim, I have the correct AC Delco/GM slave and reservoir if you are interested. Aftermarket stuff has been OK but overall can't beat factory. PM if interested. I do not have a master cylinder.
Sgreg is offline   Reply With Quote
Old 08-20-2009   #8
vettn71
I appreciate it, but I've decided that with no lift and just getting my shoulder operated on, maybe I should just have Corvette's of Dallas do the deal. They are quoting me 4.5 to 5 hours labor on the master and slave. I can hardly get it apart in that amount of time.
Old 08-22-2009   #9
vettn71
Good news and bad. Corvettes of Dallas replaced both the slave and master and all is good. The a/c, however, is another story. I'll continue the post in my rabnt on the a/c crapping the bed.
