![]() Join Date: Nov 2007
Regarding my miss/low compression issue, I was pretty certain I was dealing with a mechanical problem on my #8; a bent valve or broken valve spring, or ingested a screw or something?
![]() ![]() I was pretty much resigned to an engine pull, and initially intended to inquire about going ahead with a 368 upgrade, as long as I was going to pull the LT5 and be "in there" anyway. But, I was surprised when Marc told me he was not at all sure it was a mechanical problem - could very well be - but(!) possibly the miss and even the low compression symptom could (over time) well have it's roots elswhere: injectors, coil, plug wire, or even the ECM. So! I've got a laundry list of things to eliminate before succumbing to an engine pull. If it comes to that - an engine pull that is - I'm gonna give the 368 option a hard look-see! So, in the mean time, I'll be shopping for parts; pistons that will work on stock rods (this, according to Marc, has been done successfully at SGC), sleeves, rings, bearings, cam bolts, etc. And, if it comes to that, I'm hoping I can draw on the rich experience and talent that cruises this board. (Wouldn't even think about it, otherwise!). All comments and suggestions = very welcome. P. Last edited by Paul Workman; 08-02-2009 at 08:56 AM. |
Paul,
368? All I can say is VERY COOL! ![]() Do it! Hope you find that issue soon, so you can enjoy that beast! Cheers David |
Well, so far...
Plug wires: swapped #8 with #5 (same length) Coil: swapped places w/ the front two (the #7-6 coil now serving 8-5, if memory serves) Injectors: swapped places; #8's injectors now in the #4 spot. I shoulda checked resistance of the (Multitech! ![]() ![]() So! The question is, which cylinder is going to miss now? If it is #5, it is a bad plug wire. If it is #4 - the injectors. If either #7 or #6 fails - the coil comes under suspicion (plugs were eliminated earlier). If it is a combo... ![]() Sound like a plan? P. |
How about if you just bring the car up here and let's throw a scantool on it. I really doubt it's an ECM.
#5 | |
Forget all questions above,and ask where is all that compression pressure going.When I checked your compression it was less than 60 PSI and your leak down was at 80% .This is your problem,and it has to do with your pistons,rings,or valves nothing more. AL. Last edited by ALZR1; 08-03-2009 at 11:32 AM. |
![]() Join Date: Dec 2003
Might the list also include the head gasket? Was compression rechecked with a squirt of oil in the cylinder? Could help in determining whether or not valve problem.
![]() If it was the head gasket you would either have A cooling issue,or an adjacent cylinder down on pressure as well or both on an LT5 Motor. Paul's motor doesn't have any of these problems Paul also had checked the rest of the cylinders and said that they were about 180 PSI. AL. |
#8 | |
Granted, a head gasket, fully blown, would cause (1)temp issues, and at the very least, (2)areation in the coolant, both of which should be readily detectable. I'm not saying it IS a head gasket, just that it might also be a possibility since head gaskets have a greater incidence of failure in the LT5 than valves or piston/rings, under normal conditions. The other less frequent possibility is for a secondary butterfly shaft screw gets ingested.
#9 | |
AL. |
#10 |
Of course not.
