#11 | |
![]() Join Date: Aug 2006
Reason I am asking is, at least in my case, my 94 would run just fine until engine temp hit around 190 or so. At first, I thought it was open loop/closed loop issue. It turned out, at least in some cases, injector would run fine until it heated up at which point it would start to short out internally. Also, #3 and 4 are not on the same coil. I think #4 and 7 and #3 and 2 are correct pairing for coils. |
#12 |
![]() Join Date: May 2009
I let it warm up but maybe I didnt let get warm enough, I 'll try again later, gonna do some reading on pulling the plenum..
#13 | |
http://www.corvetteactioncenter.com/...8/002/article/ http://www.corvetteactioncenter.com/...procedure.html Since 2002 I must have pulled the plenum 4-5 times. Good news is that it gets easier every time. ![]() |
#14 |
Some GREAT pics and very clear/concise info in these threads here on the forum:
http://www.zr1netregistry.com/forum/...ead.php?t=7614 http://www.zr1netregistry.com/forum/...ead.php?t=9123 There's lots more where this came from, just click on the search button and type in "Plenum Pull". TomC "Crabs" Last edited by tccrab; 07-21-2009 at 12:51 AM. |
#15 |
If you know somebody that has or you yourself can get your hands on a Tech 1A, it will let you drop injectors one at a time. Same idea as what you just did, rough running when dropped or no change, either way it will help you key in on an injector problem or a bad hole as well, although sounds like you have your cylinders figured out to some degree already. I'm posting this to help you regarding your injectors, specifically.
#16 |
So I got home today I took it got it nice and warm and started to miss. I started on the even side, couldn't get to #8 (motor was hot). Not much of a difference, started on the oddside pulled #1 and no difference at all. Again worked down to #5 not much difference and again I couldn't get to #7. So I think the injector in #1 is the problem. I guess I better start my shopping list!
#17 |
Not no more!!!
#18 | |
![]() Join Date: Nov 2007
Now...You can come over and help me eliminate possible causes of my miss. Mine is wicked - indications are a valve or that it ingested something, but Marc H is not at all sure it is a valve. ![]() ![]() P. |
#19 |
#20 |
The plenum pull was not that bad and youre right once it started what a good feeling! I took it out this morning and it ran good and strong, the temp was running higher than normal gonna let it cool down and check the level
