![]() Join Date: Mar 2007
Feel free to add to the list...should be a sticky
1.Thou shalt not use Dexcool 2. Thou shalt not use hydraulic pressure in attempts remove the pilot bearing...unless thou shall want to feel the wrath of the crank plug leak
#2 | |
![]() Join Date: Aug 2006
4. Thou shalt run the motor to 7000 rpm at least once a week. |
This one is for Dominic after my 90 almost killed him last week.
5.Thou shalt place a screwdriver in the hood prop, lest thou want to be decapitated by the hand of God....or a strong wind.
6. Thou shalt not wash thy motor without assuring the plenum valley drain hole is clear.
![]() Join Date: Dec 2007
Thou shall not drive with power key off
Thou shalt know its T-45 after using a short t-40, stripping it out and moving to the next size in desparation to make it work.
#10 |
Thou shalt show up at the house of fleabay every week to look for those ZR1 specific parts and fork over 10% of all earning.
