Supposed to look at a 96 ZR1 tomorrow. VIN number actually even pulls up as a 96 DOHC 5.7L ZR1.
Is there such a thing ? DECODED 1996 Chevrolet Corvette Country UNITED STATES Make Chevrolet Vehicle Type Passenger Car Model Corvette Body Type 2 Door Coupe Restraint System Dual Air Bag; Manual-Active Belts Engine Type V8, 5.7L (350 CID); DOHC 32V Check Digit 3 Model Year 1996 Assy. Plant Bowling Green, KY Production Seq. Number 102215 Trim Level Base Drive Line Type RWD Vehicle Class Small Car Fuel Type Gasoline Manufacturer General Motors Corporation |
Now that I think about this. I'll bet it's an LT4 and the VIN decoders are just pulling it up as and LT5. We'll see for sure tomorrow but I'll bet that's the story.
![]() Join Date: Mar 2007
Federal ZR-1: Ask Goldcylon he is a expert on Federal ZR-1s
![]() Join Date: Aug 2006
No! It must be the almighty GS-ZR-1!
![]() Join Date: Oct 2004
Here's I believe the correct VIN: 1G1YY2253T5102215
The car should be black/red, single top and an LT4. It's certainly a "base car"! I mention "base car" only because it's a C60 manual air car also. A "no frills" car for sure! It's had a water pump at 98K ('07) and a PCM 64K ('02)! Original delivery: Elpaso Texas Does that sound like the car? I'd guess the car either in OKC or very close!! Last edited by WVZR-1; 06-10-2009 at 09:55 PM. |
#6 | |
It was showing up on the dealer sale tomorrow as a DOHC 5.7L V8. I did a VIN decoder on it and it also showed a DOHC 5.7L V8. I looked up a few LT4's and found similar VIN's....... that's what it is. |
Google is a "VERY GOOD" decoder! You can Google any VIN and if it's a legitimate VIN it will decode for anything that carries a 17 digit VIN since '81. If it's '81 or newer and Google doesn't recognize it there IS something wrong with the VIN and likely the car!!
I tried the VIN after I put it together and all I got from several were 5.7 V8 16 Valve. The services performed are from a quite reliable source!! |
![]() Join Date: Jul 2004
http://www.citychevrolet.net/used-in...d61c3b6baf5e13
Is this the one? Not a ZR-1, doesn't even look like an LT-4 from the description there.
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
1gyy = base vette
1gyz = zr-1
#10 | |
