Old 02-16-2009   #1
WVZR-1
Default Re: Pinion Seal
You want to speak to the person who did your 4.10 install! What brand of gears did you buy? There's three pinion pre-load arrangements depending on the build. Shims at both bearings original Dana, a 70mm tall crush-sleeve by generally the "lesser" vendors and a 16mm collar used by the later Dana builds including Vette and Viper.
Crush-sleeves and collars are generally considered "one-time" devices!
