Old 12-17-2008   #1
8upZR1
8upZR1's Avatar
Default ZR1 Oil Cooler
Hello everyone,
I was wondering about the oil cooler on our cars. It looks relatively large but how good is it?? Is the pressure drop large? Also does it clean/flush nicely? My ZR1 is a 1990 and I am about to fire a new motor so I dont want any issues from the original oil cooler. Are replacements available?? Does anyone have any experience with aftermarket units? I dont think there is that much trash/gunk is mine but Id like to be safe.
Old 12-17-2008   #2
Default Re: ZR1 Oil Cooler
Originally Posted by 8upZR1 View Post
Hello everyone,
I think the ZR-1 cooler is as good as any other.
Never measured it but seems very un-restricted when I "tried" to blow the oil out with air once. Design & tube size indicates negligable pressure drop to me.
Not particularly, because it's not a single tube. There are several large (0.5" i.d.?) tubes with a tube plate on each end, much like a radiator. Good from the standpoint if 1 tube plugs, the rest are open. Makes it difficult to flush & insure all tubes are open, but I can't imagine what would plug a tube. I don't even try to get the old oil out when changing anymore.
No direct aftermarket replacement to my knowledge, but have never looked for one.
Considering the design, I would recommend removing the cooler & drain the oil by tipping the inlet/outlet to the lowest point. Then rinse with solvent by shaking the cooler with it oriented horizontal to slosh solvent from one side to the other through the tubes, repeating until clean. Then drain thoroughly, put new oil in the cooler & slosh like before, then drain again.
Obviously I don't have any aftermarket knowledge, but unless your oil cooler is damaged, I doubt the lines will be plugged, but may have some gunk similar to the engine, if any.
Old 12-17-2008   #3
tccrab
tccrab's Avatar
So, tell us more about this new motor.
What did you finally put in?
TomC
"Crabs"
Old 12-17-2008   #4
Jeffvette
What you will find is the aftermarket cooler is more compact, weighs less, and offers more mounting configurations than the factory piece. Since you are not running the LT5 anymore, I don't think you are worried about using factory components.
Old 12-17-2008   #5
Tyler Townsley
Hello everyone,
Oil coolers are next to useless in a LT 5. If you look in the manual you will see that there is a thermostat in the front housing that controls oil flow through the cooler, this little gem does not open until the oil temps approach 240 deg which is a little to late for any real help in keeping the oil cool. I believe there was a lengthy discussion covering cooling issues some time ago that explained this and other shortcomings in cooling the LT 5. Do a search on my name and it should come up.
Tyler
Old 12-17-2008   #6
jonszr1
jonszr1's Avatar
is there a way to change the opening temp?
Old 12-17-2008   #7
Jeffvette
Tyler
Tyler, he no longer has a LT5.
Old 12-17-2008   #8
Tyler Townsley
Short of taking it out I have not found one with a lower opening point. Not to say there is not one but I have not seen one.
Tyler
Old 12-17-2008   #9
8upZR1
8upZR1's Avatar
Where is this thermostat located? Is it in the actual cooler? It sounds like something I would remove but I dont remember seeing anything "funny."
I'm probably just being paranoid, but I like everything to be as perfect as possible. Nothing to worry about when I sleep. For the sake of an easy life I sold the BBC and used that $$ + the $$ from the LT5 stuff to build a SBC. Not just a SBC, but a nice one. Dart lil M, 406" SCAT rot as, MAHLE pistons, AFR 227 Elim, LUNATI solid roller, CROWER SS shaft rockers & lifters, MANTON pushrods (yes pushrods, but not just any, 7/16" to 3/8" single taper .120 wall), Super VIC, QFT 950.
Im not exactly thinking of it as a step down from the LT5 in performance or durability. It should put a smile on my face. I still have some details to work out but Im hoping that by the end of the year the car will be done.
One of the big ?s Im struggling with is what to do about the thingy thats gonna be sticking out of my hood. Scoop? Open? Cowl? just no time to think about somkething like that.
Old 12-17-2008   #10
Jeffvette
It's in the oil filter housing.
