Old 10-31-2008   #111
Zr1 Destroyer
Zr1 Destroyer's Avatar
Default Re: LT5 Assembly Project
LT5 Stamped plug wires (The sales on these alone could pay for the entire tooling of the above items)[/quote]Lol.....that's no joke there!
Zr1 Destroyer is offline   Reply With Quote
Old 10-31-2008   #112
flyin ryan
flyin ryan's Avatar
Well, here is my gameplan going forward. I am going to clean up alot of the parts tomorrow, and put them in storage bags. If I am to properly clean up the block, I need to remove the crank.
So once I make sure everything is well labled and put away, and I have some more room, the girdle will come off. Check the bearings, and decide what I am going to do about the crank bearings.
I think everyone would probably want to see this, along with the install.
Let me know your thoughts. Are there things people would want to see better pictures of??? Also let me know it there is anything else that I am going to screw up or cost me out the A$$.
I think when I am done, I am going to put this into a summary of some kind to weed out alot of the mistakes, etc.
92 ZR1
#234
i asked you this already, via PM, but don't you think gave me response...have you been able to check the thrust clearance? do it before it comes apart. might have to be a little aggressive if your rear main seal is still installed.
Old 10-31-2008   #113
I will check it once I get everything organized and cleaned up.
92 ZR1
#234
Old 10-31-2008   #114
flyin ryan
flyin ryan's Avatar
92 ZR1
#234
o.k....if you want me to walk you through it again, let me know
Old 11-01-2008   #115
Personally, I would like to see good pictures of all the bearings, rods & mains, numbered to the respective cylinders & journals. I have a personal interest in oiling on the 375 hp engines.
Old 11-01-2008   #116
Here is what I did, used a wrench for a BMW made of flat steel. Gently pryed against the crank, then used a feeler guage to measure the end play. The difference was .006, measured several times from both ends.
92 ZR1
#234
Yes I know I should use a dial indicator.
Old 11-01-2008   #117
flyin ryan
flyin ryan's Avatar
92 ZR1
#234
if that's what it is that's killer...forget about the fact it has some miles on it...i'd take .006" on a freash set of bearings/build everytime
Old 11-01-2008   #118
Has anyone checked the bearing sizes for the Lotus V8s, seems odd that they would not use some sizings that were already available to them.
92 ZR1
#234
Old 11-01-2008   #119
92 ZR1
#234
I need the "I agree" thing. I hate using the one we have.....it's kind of insulting IMHO....
Why would Lotus not use "on hand" stuff if it would work? I mean the V8 in the Land Rover was the BFO after they told the guys at chevy that a 4 cam head conversion would not be cost effective at all.
Okay, okay, I should not talk as I don't know all that much about our motors. But it just seems like the path of least cost/resistance.....KISS school of thought & all...No??
Okay, I just read the post from Kurt.....I guess that kind of says why we can't get replacement bearings easily.....by extension it is obvious that Lotus didn't use any on hand stuff? I should not read the last page in a thread first!
Old 11-01-2008   #120
I will check on the Lotus possibilty later, in addition to the hemi option. I did do some measuring this morning with a digitial caliper:
Most pistons measured 3.87(2-3) and liners were at 3.89(1-2). Even the damaged pistons were within specs,
The rod bolts generally measured 54.38-54.5MM.
92 ZR1
#234
I will be picking up a dial guage in the next few days and will take some pics on proper way(or at least the rank amateur way) to check endplay in the crank.
