Old 10-19-2008   #21
Default Re: LT5 Assembly Project
The Pistons have damage from a screw...apparently the culprit was never found, but he either had partners or possibly bounced around from cylinder to cylinder:
There is however no damage to liners.
92 ZR1
#234
Old 10-19-2008   #22
The only known other issue is the cross threaded bolt for the IH:
91 ZR1
#234
Old 10-19-2008   #23
Step one in inspecting the block, etc was the removal of the balancer.
In order to hold the crank still, I placed a large head screwdriver in the crank position sensor hole, the crank has several notches in it, used for holding the crank still during cam timing. There is actually a tool that is inserted here that snaps into the notch and holds the crank still, but more to come on that. After locking the crank I removed the crank/balancer bolt.
Crank position sensor hole:
Then removed the balancer:
Old 10-19-2008   #24
Zr1 Destroyer
Zr1 Destroyer's Avatar
Originally Posted by phrogs View Post
I still have to pull up the BS flag on the head bolts...
Who else here has worked on a LT5 and replaced the head bolts?
just curious
I re-used my bolts from my 368 for the 415 build and all is fine.......just turned them a few extra degrees with the wheel on the end of the torque wrench. I also re-used my head bolts on my old Z when I did the ported lpe heads from nj.
Zr1 Destroyer is offline   Reply With Quote
Old 10-19-2008   #25
Yeah but LGAFF has NO Head Bolts.. that is the issue
Old 10-19-2008   #26
Zr1 Destroyer
In order to hold the crank still, I placed a large head screwdriver in the crank position sensor hole, the crank has several notches in it, used for holding the crank still during cam timing. There is actuall a tool that is inserted here in that snaps into the notch and holds the crank still, but more to come on that. After locking the crank I removed the crank/balancer bolt.
Yeah....you'll for sure want the crank pin tool....things will get ugly real fast if a guy guess's on that one.
Old 10-19-2008   #27
Zr1 Destroyer
Hmmm...nj has a surplus on these.....I'll ask him if he wants to get rid of some. He also has five extra sets of cams also he wants to punt.
Old 10-19-2008   #28
It seems to me the tool is only needed to locate the proper hole, which I believe they state is at about 51 degress BTDC. The hole for cam timing is deeper that the others, and the pin tool drops flush in the proper notich. I would think that one could use a measured dowel to accomplish the same running a few rotations to ensure that you chose the correct notch.
92 ZR1
#234
Old 10-20-2008   #29
Zr1 Destroyer
92 ZR1
#234
You could for sure do that, but the pin lock tool was in hand at the time of my build and made life easy for a moment during my last build.
Old 10-20-2008   #30
Jeffvette
So you are forcing roughly 160+ ftlbs of pressure on the crank reluctor wheel?
