Old 10-14-2008   #21
Default Re: Engine Parts
Did you talk to Jeff Flint AKA Jeffvette? $1200 is insane for a set of bolts!!!
Old 10-14-2008   #22
Jeffvette
M14 x 1.5 x 220mm
Old 10-14-2008   #23
Jagdpanzer
Jagdpanzer's Avatar
Parts book specifies 14X1.5X80
Can someone confirm this is the correct size head bolt?
Do the factory LT5 head bolts have any special feature?
Fastenal has 10.9 grade bolts listed in this size.
Old 10-14-2008   #24
Polo-1
I can tell you it's NOT 80mm. Thats only 3.149 inch. The bolts go from the top of the head to the bottom of the block.
Old 10-14-2008   #25
What Jeff said.....14 x 1.5 x 220
Thread length is 62mm. Bolts must also have the flat ground, hardened washer. Obviously the washers can be reused, but if you have NO head bolts, the washers will be required also. Bolt head has an integral flange under the hex. I would imagine the prudent thing to do would be to send a stock head bolt to ARP to copy the configuration. I'll go so far as to say the result will be sticker shocking from ARP as well. It's a really big bolt.
Old 10-14-2008   #26
Jeffvette
M14 x 1.5 x 220mm
Old 10-14-2008   #27
ARP sent a form to fill out, they want actual measurements including gasket material etc. They stated they may have otherbolts that match.
PDF file is too big to post here.
I can't believe these frggin head bolts are more than I paid for a shortblock.
92 ZR1
#234
I wonder what ACE hardware has in stock.
Old 10-14-2008   #28
Polo-1
Stroker Crank.......... check
JE pistons................check
Oliver rods...............check
SGC Cams................check
Made in China bolts to hold it all together.........
Old 10-15-2008   #29
flyin ryan
flyin ryan's Avatar
yup...that's what you gotta have is the form. got a bunch here at all times, unfortunatly. the main measurment they will want above all else is U.H.L. (under head lenght). also, i always shoot for maximum thread lenght in(to) an aluminum block.
Old 10-15-2008   #30
rkreigh
guys,
Ron and Randy Woods
ZR1 Specialty Products make head studs that work just great
they worked with ARP to design just the right stuff and are both cheaper and superior to stock
give em a shout
