Old 10-01-2008   #11
jonszr1
jonszr1's Avatar
Default Re: Spark Plug Gap
so would you suggest 35 for every year ?. guess i am going to try 35thou at the strip on fri . i have maybe mistakenly so used 40 -48 thou as gap .it will be fun to find out if it helps at all . thanx for the info pete
Old 10-03-2008   #12
karterdon
karterdon's Avatar
THe reason for the change in gap is that the ignition system received a boost. That's why the gap increased. It was not because of the plugs. If you change your coils to MSD - you could go to a slightly larger gap. The MSD coils have a bit more voltage out put then the factory coils. So if your current gap is .035 I would leave it there or go a go slightly tighter to .032. Coils can work easier.
Best of luck
Don Yoakem
91 #267 Dark Red Met.
karterdon is offline   Reply With Quote
Old 10-03-2008   #13
Pete
Pete's Avatar
Best of luck
Don Yoakem
Brad,yes i would go .035 on any year Z.
Don, you are the man .032 is perfect, like you
I agree with Don on this.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-05-2008   #14
karterdon
karterdon's Avatar
I am just a humble supporter of making things go faster with less work.
