07-12-2008 | #1 |
SLP intake filters
Hi everyone
Just bought an SLP intake and the filters are squashed. Does anyone know what the filter replacements are or where I can get some. The filters that are on it are K&N and have a number on the end that reads B03584 which could be a serial number but the K&N site doesn't recognise it. Thanks Dave
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
07-15-2008 | #2 |
Re: SLP intake filters
dave,carefully check all clearances,as mine hits the underside of the hood,at the reinforcement brace
bj |
07-15-2008 | #3 |
i would put the stock box, cut lid, paper filter back on. sorry i can't be more help
07-15-2008 | #4 | |
07-15-2008 | #5 |
I haven't put it on yet, I hadn't heard of any clearance problems though. Thanks for the heads up, I'll check it. If anyone knows the filter p.no. I'd still appreciate it.
07-15-2008 | #6 |
the slp filters are made my blackwing not k&n
07-16-2008 | #7 |
I'm quite confident the K&N # is RB-0720. The flange where it attaches to the "intake tubes" is NOT straight, it has a small angle to it. I measured mine dimensionally and used their calculator and its a "dead match"! Mine is an SLP commonly referred to as the "Claw" I believe.
Here's a link to the dimensions, you should be able to confirm them. I used their main page and the "by dimension" calculator on the left. I used only the exact dimensions of OD, Length and ID of intake. The flange angle is/was unknown! http://www.knfilters.com/search/prod...x?Prod=RB-0720 I believe that SLP provides some spacers for the fit to the "upper shroud" and you don't use any of their hardware. I don't recall any clearance issues. A clearance issue could be caused by the "angle" of the mounting flange not being "rotated" to the correct orientation on the intake. Use two of your air cleaner "thumb screws" and fit the assembly to your shroud. Looks substantially better NOT using their hardware. Last edited by WVZR-1; 07-16-2008 at 02:51 AM. |
07-16-2008 | #8 | |
07-16-2008 | #9 |
They definitely used K&N filters before the blackwing ones. Mine has K&N also. I thought I saved one of the box tops to keep the part #, but I can't find it...
07-16-2008 | #10 | |
