Go Back   ZR-1 Net Registry Forums > Off Topic > OFF TOPIC
Old 04-28-2008   #1
fred
fred's Avatar
Default Re: old school mechanics, step inside
Yes, I think it is, don't forget about the pickup coil in the distributer.
fred is offline   Reply With Quote
Old 04-30-2008   #2
GrayZ
thanks for those that replied to the post, i will try you're home remedies
Old 05-01-2008   #3
WydGlydJim
WydGlydJim's Avatar
It needs to be hooked up to a scope while presenting the problem. If it is the ignition module, it will be evident by the scope pattern. If you feel it is fuel, then you should be able to keep it running by squirting some carb cleaner into the throat of the carb, while it is presenting the problem, and it should correct somewhat and run while the scope pattern should remain normal. I have seen the sock in the tank also collapse, then relax, collapse, then relax, etc........
2009 LS9
1990 LT-5/sold/Bought my Baby back
1994 Lingenfelter LT-5/sold
1973 LS4/sold
WydGlydJim is offline   Reply With Quote
Old 05-01-2008   #4
GrayZ
i spoke with a local old school mechanic today
he told me the coil inside the distributor
is probably my problem, he also said if that did not
fix it, that, it my be a timing chain as it backfires
a little through the carb, when it' starts to die.
thanks everyone for the great advice. i'm gona leave
no leaf unturned. got to get her ready for football season.
