#11 | |
![]() ![]() Join Date: Nov 2007
I should have explained that my "Yep" was simply in agreement that it was doubtful that (in effect) regardless of the high-end oils used, it is perhaps unlikely to experience an oil-related failure. I'm ![]() Like I said: truth is where you find it. If you've got some valid test results and comparisions, bring 'em on. It would be interesting to see a comparision of AMO to Redline products. But, in the end it might be pickin' the fly specks out of the pepper - both may well exceed lubrication requirements of the LT5 in most situations. So, it may well be true that with either oil it is probably unlikely I will suffer a oil-related failure (in normal circumstances). My fault for my flippant "yep". P. |
#12 | |
![]() Join Date: Jul 2005
Nick ZR-1 Net Registry Founding Member #32 - lapsed... |
#13 |
![]() Join Date: Jun 2004
I appologize to all as I get a bit one sided when it comes to oil and in the true perspective it's all up to the individual. Nick, you've always been a good, straight shooter and I value your opinion as I do all of you.
I should NOT have singled out Marc so please make up your own minds and I'll do the same. We are all brother of the LT5/ZR-1 and all proud of it, too. Let's all just get along ![]()
#14 | |
#15 |
10W-40
100% Synthetic API SL/CF,CI-4 Plus Probably a special order from a dealer except Marc |
#16 |
![]() Join Date: Aug 2005
mark probably sell amsoil for the same reason i sell it in my shop......cause i like the product;and,like me,he probably doesnt care if he sells 10 cases,or a hundred...after opening so many harley engines,i can see the difference in wear amsoil makes...i can sell any oil i want,but i trust amsoil more than other brands...red line is probably just as good,but is hard to get around here
bj 91/1735 |
#17 |
![]() Join Date: Jan 2008
Just as an FYI - Mobil-1 sysnthetic became factory fill on all ZR1's beginning in 1992 and since GM had to stand behind the engine warranty - Mobil-1 is probably a pretty good oil. As often as we all change are oil - I don't think any of us have much to worry about if you are using any quality brand name oil under normal conditions - If you have Modified your engine - Then the research for a higher quality oil for a heaver engine demand / load's - Like racing, Turbo's, Nitros etc. is in one's best interest.
And so the debate continue's !!!! ![]() Don Yoakem 91-#267 Dark Red Met. |
#18 | |
![]() Join Date: Dec 2004
I also don't think I've ever actually made it to 5k miles on a M1 change either. ![]() ![]() Tom
