View Poll Results: Which oil do you use?
Amsoil 79 22.13%
Castrol 19 5.32%
Champion 0 0%
Chevron 0 0%
Conoco 0 0%
Citgo 0 0%
Havoline 1 0.28%
Interstate 0 0%
Kendall 1 0.28%
Lowe 0 0%
Marathon 0 0%
Mobil 1 224 62.75%
Motorcraft 0 0%
National 0 0%
PennZoil 4 1.12%
Quaker State 3 0.84%
Redline 10 2.80%
Royal Purple 11 3.08%
Valvoline 5 1.40%
Voters: 357. You may not vote on this poll
Old 04-30-2007   #31
lbszr
lbszr's Avatar
Default Re: Which oil do you use
Originally Posted by Aurora40
I just poured 8.5 quarts in today of Redline. Started it up to fill the filter and once it settles I'll top it off. Dunno if the car will run any diff, but holy crap is that stuff a pain to pour! You have to pry off the seal from each bottle, and with that slim neck and small opening they pour soooo slowly!
I thought the same thing, I figured when I drop a bottle(which I probably will) maybe I can get it picked up before the small fortune all runs out. I'm sticking with it though, suppose to be some good stuff!
Old 11-08-2007   #32
Mika73
Castrol TWR 10W60
Mika73 is offline   Reply With Quote
Old 11-09-2007   #33
HIZNHRZ
I hear Mobil 1 isn't what it used to be but I also use it in everything I own.
Old 02-01-2008   #34
Nick
I just switched to the Amsoil AMO 10w-40 per Marc Haibeck's advice. Found it locally for no more than any online price I came across, less shipping costs.
Old 02-01-2008   #35
32valvZ
32valvZ's Avatar
Amsoil 10w40here too, for the same reason Nick says...
Old 02-01-2008   #36
bradslt5
Mobil one turbo deasel 10-40 4qts mobil one ext. 10-30 4 qt i can restorer. for the zinc it adds. 144k and hardley eats a drop?
Old 02-01-2008   #37
HADI-ZR1
within 2 years I use 2nd time !
FormulaShell® Full Synthetic 10W-30
Old 03-31-2008   #38
DaveK
I've been using Mobil 1 but switching to Amsoil as per Marc's write up.
1991 #1516 Black/Black
davidmkelly.com
Old 03-31-2008   #39
DMark
DMark's Avatar
I'm now using 10W40 Mobil 1 High Mileage because its as near as we'll get to the original M1.
And 5qts jugs are still $21 at Walmart.
DMark is offline   Reply With Quote
Old 04-01-2008   #40
ZR1Vette
ZR1Vette's Avatar
Amsoil AMO based on Haibek's analysis and ASTM comparative motor oil testing
Michael
