02-28-2008 | #1 |
VIBRATION AND BODY BOOM: PROBLEM WITH THE NEW DIFFERENTIAL 4,11 GEARS
Changed for new:
Zip Products: Product Number: SU-1117: NEW DANA 44 DIFFERENTIAL, 4.11 GEARS Rock Auto 2-Universal Joint ACDELCO Part # 45U0111 GREASABLE U-JOINT #89029293 4-Universal Joint ACDELCO Part # 45U0109 GREASABLE U-JOINT #89029291 VIBRATION AND BODY BOOM Checked Propeller Shaft Balance: Disconnected Propeller Shaft from pinion yoke and rotate the propeller shaft 180 degrees. I continue with same problem to superior speeds of 75Mp/h. Some idea to be able to solve? Frank Teixido Barcelona/Spain Member 451
AM.C.C.C. |
02-28-2008 | #2 |
Re: VIBRATION AND BODY BOOM: PROBLEM WITH THE NEW DIFFERENTIAL 4,11 GEARS
double ck your u joints could be a flat bearing in one of them.did one of the caps fall off during instalation. 2 you want to be very carefull getting on it with geasable u-joints they are alot weaker due to the zerk fitting . if it were me id chuck those and get the best ones i could find without zek fittings .
03-01-2008 | #3 |
This might be a silly question.
Did you tighten the differantial C-beam long bolts and the transmission C-beam bolts. Pete
03-05-2008 | #4 | ||
Just an update, this is what I sent Frank in a email.
And Franks Reply Quote:
03-22-2008 | #5 |
It thought that it had found the problem in the U-Joint of drive shaft that according to indicated the mechanic to me had movement.
I bought another U-Joint without greasable, when we removed it and we changed, seemed to me that it did not have any problem. I took to balance propeller shaft and turned out after to them to have indicated the model of the car could not by lack of supports. I returned to mount without making the balance and with the new U-Joint and follow with he himself problem. I explained the problem to the mechanic of my GMC 4X4 Jimmy. It indicated to me to control halft shaft that the U-Joint greasable was to 180 Degrees. Controlling I have seen that those of the right are to 180º of another one. but those of the single left are to 90º. It could be the cause? Some reference?
AM.C.C.C. |
