View Poll Results: Which Performance Chip do you have?
Corvette Consultant 5 1.69%
Doug Rippie Motors(DRM) 53 17.91%
Ebert's Engine Service (EES) 3 1.01%
Formato's FasterPROMs 0 0%
Jeal 4 1.35%
Leonhardt Automotive 1 0.34%
Marc Haibeck 180 60.81%
Marc Randolph 11 3.72%
Southern Georgia Corvette (SGC) 12 4.05%
Todd Pepmeier 4 1.35%
TPIS 0 0%
Vette Doctor 0 0%
Z-Industries 7 2.36%
Team ZR-1 3 1.01%
Corey Henderson (DynoTex Racing) 13 4.39%
Voters: 296. You may not vote on this poll
Old 07-13-2021   #141
tgonyaw
Default Re: Which Performance Chip do you have?
Haibeck chip here.
tgonyaw is offline   Reply With Quote
Old 07-14-2021   #142
JSad
JSad's Avatar
Haibeck here too
1991 ZR-1 #0210 artic white/black
1995 Coupe Auto; pologreen/black (sold)
1993 Convertible Manual; pologreeen/tan (sold)
JSad is offline   Reply With Quote
Old 07-15-2021   #143
mcich7781
mcich7781's Avatar
Haibeck Chip burned specific for my car during dyno-tuning.
Sent from my SM-G955U using ZR-1 Net Registry mobile app
mcich7781 is offline   Reply With Quote
Old 08-03-2021   #144
Matt B
Matt B's Avatar
Just installed Haibeck yesterday. Incredible improvement over the 1st generation 91 OEM calibration. Worth every penny.
Mine is slightly modified to maintain low power mode standard on startup - because it's such a cool feature [emoji106]
Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991
Old 10-28-2021   #145
sleazy rider
my 91' z had its chip modified by john lingenfelter, anyways his shop did, when they did the 530hp package. this past year i had marc haibeck perform his magic to it.
sleazy rider is offline   Reply With Quote
Old 01-28-2025   #146
Figure8it
Figure8it's Avatar
I had Marc pull my DRM chip and tune my Z on the dyno with his. Here is a link to the video I posted on YouTube https://www.youtube.com/watch?v=UxGPzj1KUuk
Figure8it is offline   Reply With Quote
Old 01-29-2025   #147
Mikey
My 1991 is a Corey Henderson 368ci build. I have suspected serious tuning issues ever since I bought it in 2020. Made the trip from Nashville to Chicago to get it to Marc and after taking some 02 readings confirming it was rich at the lower end and down on power (too lean) at the upper end and verifying good fuel pressure we took a look at the programming and confirmed exactly what I suspected and even found the root cause of a stumble at 5500rpm that I had noticed.
Haibeck completely reprogrammed and tested multiple runs and the wide band O2 readings are great now all throughout the range. Idle is so good now that you can hardly hear the aluminum flywheel rattle anymore. Very smooth.
Looking forward to making a few passes at Beach Bend in May. Will report back compared to last time I was there. I expect to pickup 4-5mph vs previous time.
If that proves out I will officially declare Marc the best tuning wizard for the LT5. As it stands drivability is as good as my stock C6 Z06 LS7 powered car.
Old 03-22-2025   #148
tiegsd
tiegsd's Avatar
Haibeck.
1990 Black/Black ZR-1 #1155
Old 4 Weeks Ago   #149
AlbanyBrian
AlbanyBrian's Avatar
This is the chip that is installed in my 1993, #135. It was installed by someone other than the person I purchased the car from. I do not have the history for my car from owners prior to the person I purchased the car from. It also has headers, no cats, x-pipe and Borla mufflers, relocated MAT sensor, K&N air filter, open air filter cover, Jerrys Gaskets air coupler, and 4:10 gears. The runs good.
Brian
1993 ZR-1, #135, cool car
2008 Z06, fun car
1985 RIP, was a fun project/track car
AlbanyBrian is offline   Reply With Quote
