![]() Join Date: Dec 2011
Early 1990 LT5 - a slow leak in the system so time for a new master & slave. Problem is I'm overwhelmed by the choices on Rock Auto - 3 clutch master cylinders from $34.79 to $37.79/ 7 clutch slaves $35.79 to $122.79. Would appreciate any suggestions as to how to choose. Rick - Bethesda, MD
![]() Join Date: Feb 2023
I have not looked into the RockAuto choices. Last spring I replaced my 1993?s slave with one from Corvette Central (CC). They had several choices, the cast style replacements and the tube style replacement (like the OEM). I don?t think there is one that is better than the other with respect to function. The tube style is like OEM if that is important to you. They have MC?s as well but did not need one so I didn?t investigate their options. I am not saying RockAuto?s choice aren?t as good, I only have experience with the CC choices. Good luck.
Brian
1993 ZR-1, #135, cool car 2008 Z06, fun car 1985 RIP, was a fun project/track car |
Brian - thank you for sharing your experience. That is exactly what I was looking for. Rick
![]() Join Date: Aug 2006
Rick,
This is secondchance - Yun. Check your message and call me. |
#5 | |
Any info/tips would be much appreciated. Cheers, Russell 🇦🇺 |
Russell - My plan is to replace both the master and slave cylinders. I have sourced both from eBay and went with LUK. The challenge now is replacement. Wish me luck! Rick
![]() Join Date: Sep 2016
I have also had good success several times with LUK hydraulic clutch parts also.
First question, call Jerry's Gaskets. He will have what you need.
Second question. The missing fluid is soaked into the interior carpet of your car. Unless you want to replace the carpet in your car, change the master cylinder now. Trust me. I'm not wrong about this. And, depending on how much hydraulic fluid is already on your carpet, you might need to replace it anyway. Crabs Last edited by tccrab; 4 Weeks Ago at 11:53 PM. |
#10 | |
I will order both Master and Slave cylinders ASAP.👍 Cheers, Russell 🇦🇺 Down under |
