Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 NCRS Topics
Old 08-02-2024   #1
bmarcum
Default Oil Cooler Lines
Anyone repairing the hydraulic crimps on the oil line coolers. Long story short, I purchased a 14K mile car that has been driven. Lots of little stuff to make it the driver it needs to be. I like keeping most stuff on the car ZR-1 or hipo. I have owned two previous Z and never had any issues with these lines. I see that the GM line is discontinued and just curious to see if anyone repairing the lines. I see Jerry has replacement lines but I would prefer stock (or stock appearing) for this repair. Any help appreciated! Thanks
bmarcum is offline   Reply With Quote
Old 08-04-2024   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Oil Cooler Lines
In industry flex hoses are generally considered to age limited. Our cars are now pushing 30+ years. Given that more and more oil cooler line failures are to be expected. The OEM lines were not the best quality available at the time. Therefore I would stay away from any used or NOS lines at this point. Suggest trying a local hydraulic shop to see if they can reproduce a set of new lines that appear like OEMs.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-04-2024   #3
I have what I believe to be OEM or the Gm replacement lines that aren't leaking yet..
Old 02-08-2025   #4
ZBrink
Forum Chairman
ZBrink's Avatar
I recognize this as a needed item since the aftermarket ones are very expensive and require custom-made adapters. I'm floating my OEM set around some heavy equipment shops who make custom hydraulic lines to see if anyone can rebuild them. I will report back what I find!
Zack Brinkmeier - Forum Chairman, ZR-1 Registry
forum@zr1netregistry.com
1990 ZR-1 #299, Bright Red/Red
