Old 1 Week Ago   #1
ZBrink
Administrator
ZBrink's Avatar
Default Has Anyone Compiled a "Parts Catalog"?
I've been been building out a spreadsheet with ZR-1/LT5 parts, part numbers, and hyper links to vendors who either manufacture or sell them. I intend to post the spreadsheet on the forum as a Sticky. It's A LOT of work though and I don't want to re-invent the wheel.
Has anyone done something similar who would be willing to work with me on this?
Zack Brinkmeier - Forum Chairman, ZR-1 Registry
1990 ZR-1 #299, Bright Red/Red
1998 Z51 Fastback Coupe, A4, Torch Red/Oak
Old 1 Week Ago   #2
Default Re: Has Anyone Compiled a "Parts Catalog"?
I go to jerrysgaskets.com for as complete a parts list and supply of parts for the ZR-1 and LT5 as you might find anywhere 👍
His first page lists a complete category of parts you might consider in your effort
Jerry is A26B
Another member that has provided me many aluminum machined items such as oil filter caps, coolant reservoir caps, 87/91 octane fuel line brackets etc is Carter (Carter200) .......Carter's machining ability is perfection 👍
Another thing you might consider which I have done in my CF Sticky is consider that individual parts sometimes vary a bit in design making the year ZR-1 you have (90,91,92,93,94,95) significant
Old 1 Day Ago   #3
RSLyrick
RSLyrick's Avatar
There was a PDF file available on the main Registry website at the end of the following page :
https://www.zr1netregistry.com/Infor...tsManuals.aspx
But the link is no longer functional. I still have the PDF file if needed. The scan quality is however not that good. Quick search is then not possible. Recreating this document content into a spreadsheet is a great idea.
RSLyrick is offline   Reply With Quote
Old 1 Day Ago   #4
ZBot
I'm new to the Zr1 community and am looking to buy my first Zr1 soon😎(hopefully within the next few weeks).
I'm up for making a spreadsheet out of the PDF. Are you able to send me the PDF?
ZBot is offline   Reply With Quote
Old 1 Day Ago   #5
RSLyrick
RSLyrick's Avatar
Here it is (for registered forum users)
You're not a member (yet), so you probably can't get the attachements.
Since this document was from the registry website, could an admin quickly confirm that I can release such document publicly or not ? (via WeTransfer for exemple)
Edit : I have issue downloading the file from the forum. Size of the downloaded file is only 16MB instead of 40MB...don't know what's happening.
Old 23 Hours Ago   #6
Mikey
same issue - and file won't open once the 16MB is downloaded.
Old 14 Hours Ago   #7
RSLyrick
RSLyrick's Avatar
I tried to upload it again, still not working.
Can an admin check what the problem is ? Or confirm that I can just use WeTransfer for this file ?
Old 2 Hours Ago   #8
ZBrink
Administrator
ZBrink's Avatar
I have no issue with you making this public and would welcome it! If they are GM part numbers, they will undoubtedly be obsolete by now but will provide a jumping off point for ACDelco replacement part numbers, aftermarket part numbers, etc. Thank you for working this!
