Old 6 Days Ago   #1
ZBrink
Administrator
ZBrink's Avatar
Default Has Anyone Compiled a "Parts Catalog"?
I've been been building out a spreadsheet with ZR-1/LT5 parts, part numbers, and hyper links to vendors who either manufacture or sell them. I intend to post the spreadsheet on the forum as a Sticky. It's A LOT of work though and I don't want to re-invent the wheel.
Has anyone done something similar who would be willing to work with me on this?
Zack Brinkmeier - Forum Chairman, ZR-1 Registry
1990 ZR-1 #299, Bright Red/Red
1998 Z51 Fastback Coupe, A4, Torch Red/Oak
Old 6 Days Ago   #2
Default Re: Has Anyone Compiled a "Parts Catalog"?
I go to jerrysgaskets.com for as complete a parts list and supply of parts for the ZR-1 and LT5 as you might find anywhere 👍
His first page lists a complete category of parts you might consider in your effort
Jerry is A26B
Another member that has provided me many aluminum machined items such as oil filter caps, coolant reservoir caps, 87/91 octane fuel line brackets etc is Carter (Carter200) .......Carter's machining ability is perfection 👍
Another thing you might consider which I have done in my CF Sticky is consider that individual parts sometimes vary a bit in design making the year ZR-1 you have (90,91,92,93,94,95) significant
Old 2 Hours Ago   #3
RSLyrick
RSLyrick's Avatar
There was a PDF file available on the main Registry website at the end of the following page :
https://www.zr1netregistry.com/Infor...tsManuals.aspx
But the link is no longer functional. I still have the PDF file if needed. The scan quality is however not that good. Quick search is then not possible. Recreating this document content into a spreadsheet is a great idea.
RSLyrick is offline   Reply With Quote
