Forum Chairman
![]() ![]() Join Date: Feb 2024
THIS IS SOMEWHAT OF A PLACEHOLDER FOR WHAT WILL BE A SPREADSHEET, PARTS LIST, OR DATABASE
Alternator AcDelco 3342318, OEM remanufactured Alternator Pulley 79401250 Belt Tensioner Dayco, OEM rebuilt Engine Mounts Anchor 2902 Westar 2902 Exhaust Headers (aftermarket) Stainless Works Long Tube Headers Fuel Pump Delphi FE0039 (2 required) Lingenfelter L710030390 (1-pump conversion kit) Ignition Coil (4 required) GM D545 Standard Motor Products DR39 Delphi GN10123 BorgWarner E51 Lug Nuts Dorman 611-109 (1 lug nut) Power Steering Pump (recommend having yours rebuilt vs buying new per fitment issues - ZBrink) Lares 12248, aluminum variant (side holes MUST be tap/died for mounting) (01/25/25: Rock Auto is refusing to update their website stating this pump has to be modified to work on the LT5 - ZBrink) Aftermarket aluminum variant, likely from Lares (side holes MUST be tap/died for mounting) (01/25/25: Corvette Central is refusing to update their website stating this pump has to be modified to work on the LT5 - ZBrink) Radiator Agility 8011052 (OEM replacement) Liland Global 1052AA (all-aluminum variant) Dewitts (direct-fit, all-aluminum, USA made) Shocks (FX3) 1989-1991 Front, Bilstein # 20-070007 1989-1991 Rear, Bilstein # 20-070014 1992-1995 Front, Bilstein # 20-070274 1992-1995 Rear, Bilstein # 20-070281 Starter GM #10455704 (discontinued) ACDelco 3361118, re-manufactured Water Pump (recommend having yours rebuilt vs buying new per fitment issues - ZBrink) GM Brazil 1307180 Wheel Lock, Lug Nut OEM Amcor Locks ---- Last edited by ZBrink; 01-27-2025 at 07:00 PM. |
