#11 | |
![]() Join Date: Mar 2008
And at least one owner stomped gas pedal in second gear to promptly blow new upper SAMCO radiator hose clean off.... ![]() |
#12 | |
![]() Join Date: Sep 2008
Same exact thing happened to me only with the original factory hose back in the 90's. Also 20 years later when I had an unexplained overheating issue, it was traced to the one of those clamps being loose enough to bleed pressure causing temp rise when stopped. So YES, be vigilant! ![]() Marty |
