#11 | |
Tech Info - RC SL4-205 injectors (500+ hp) Calculations When you are under the Plenum or otherwise wondering what modifications you can do to your ZR1....... In my signature is a thread covering the modifications of five ZR1s all having the following modifications as a minimum...... All ZR-1s have??.. C4 Beam Plates, Billet Aluminum Pulleys (Alternator, Water Pump, Power Steering), Carter Bling, Oil Cooler SS Braided Hoses, TB Coolant Blocked, New 180 deg Thermostat, New Radiator Hoses, Debris Screen, Haibeck Chips (91/87 Octane), New Aluminum Radiator, New Charcoal Canister, Reconditioned Starter, 60/80 Amp Starter Relay, Battery Disconnect, Full Power Key Reconditioned, INFL REST Sensor Re-installed, New Linkage for Secondary Port Throttles, Billet Aluminum Fuel Pump Connector, New Improved Fuel Pressure Regulator, New Secondary Vacuum System, New BKRSEIX Spark Plugs,, New Serpentine Belt, New Hood Strut, New Hatch Struts, Wilwood C5-Z06 Front Brakes, Clutch Safety Switch Bypassed, Anodized Steel Belt Tensioner Pulleys installed, 10W40 Amsoil Engine Oil, 10W60 Castrol Transmission Oil, 75W90 Mobile 1 Differential Oil, Differential Drain Plug Installed.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-08-2024 at 07:52 PM. |
#12 |
![]() Join Date: Jan 2004
won the class at gordon's school and we did injector change school
it's good to get the dvd and learn the tricks getting all injectors to seat without pinching o rings can be a challenge |
#13 | |
#14 |
I been farming in South Dakota and keeping a couple ZR1s there running in cold weather 😁😁
I use the ZR1s to get tractor parts quick 😜
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-06-2024 at 10:57 AM. |
#15 |
![]() Join Date: Dec 2003
![]() ![]() Always glad to hear from you Cliff! ![]()
#16 |
![]() Join Date: Apr 2007
Ha ha! Me too--that is, I use my Z06 (and used to use my '95 ZR-1) as my daily driver in the summer. When people at the grocery store ask me about it I tell them I need to get the ice cream home quickly before it melts. --Bob
#17 |
![]() Join Date: Jun 2022
Hey CRAZEY...So I finished up my injector swap and it's running great. I went from zero experience on a ZR1 to VERY familiar with the engine from this process. As long as you take your time and don't rush it, it's not a difficult job. If you need a hand I'm not far down the road and will be glad to help. This Forum is beyond helpful...an awesome resource!!
#18 | |
![]() Join Date: May 2010
Congrats! That?s the way to do it! I have had 3 ZR-1s over 21 years and none of them have been to a mechanic, dealer or shop. Doing all the work yourself is how you learn the car and what to do when stuff happens. Even rebuilt my own LT5 to 520 hp specs in my garage with help of others here. Sent from my iPhone using ZR-1 Net Registry
